Hope someone can give some help or suggestions.
After being broken into earlier in the year, I have finally got round to installing the alarm system that was purchased a couple of months ago.
Every thing seems to work, that is after a minor wiring fault on the global system tamper, which turned out to be poor connection on vibration sensor (front door).
The problem is the external sounder will not function at all, apart from the tamper circuit. There is definitely power from the control panel and the standby battery has 8 volts.
I have tried the trouble shooting instructions in the installation manual, which is make temp connection  between SAB B and D for the sounder which does not work and also temp connection between SAB S and D for the strobe which also did not work.
The system is all texecom, veritas excel with LCD keypad petwise PIRs and vibration sensors.
The sounder is an Odyssey 5.
