Honeywell PIR Problem Walk Test
jfrankine
Hi, I have installed my first wireless le sucre PIR on my flex system. Everything went ok with pairing until next morning I get keypad message rf batlow. Result: I am on my 3rd battery in 3 days!!
So I have changed old PIR removed serial and paired new PIR with the panel and I can see the new serial No. in th RF intruder zone (signal strength is good menu 21).
When I do a walk test I get no result from the RF zone. If I activate tamper the panel registers it. When I walk pass the sensor I get 2 long flashes then when I move after that I just get 2 short flashes. I thougth that wireless PIRs do not flash after warm up unless the alarm is set? The PIR does this wether or not the panel is in walk test mode. Could it be a Faulty RF unit (Honeywell A073-00-01)?
Does anybody have any ideas?
Many thanks in advance.
