Selecting a new alarm system
Will
Hi All,
I have an old Siemens IC60 panel with 3 wired keypads, 3 wired sensors, plus some wireless stuff (Sensors, Smoke detectors, keyfobs etc..)
I also have some z-wave and 433 home automation stuff running under vera edge and domoticz.
I am looking to upgrade this to something more modern.
My main requirements:
- IP connectivity so I can monitor remotely
- 3 wired keypads
- Images / video on movement when armed - but want to avoid standard IP WIFI cameras inside my home.
- Easier to arm / disarm (RFID, keyfobs, Bluetooth proximity etc)
- Ability to view video / images without a phone - If I am in bed, and the alarm triggers, I want to see what triggered the system before I go and look
- As much wired as possible (I only use wireless if wired is too ugly)
- Pet safe
- Added bonus - Control my lights etc
- Budget ~£1k
I am considering the Honeywell flex with a touchcentre for the visualisation of images / videos
I was also looking at Simplisafe and Jablotron from the US - but these seem to be mostly wireless.
Does anyone have any other suggestions or recommendations?
Thanks in advance
Will
Hi Will
The eaton stuff might be a good place to look
https://www.eaton.com/gb/en-gb/products/safety-security-emergency-communications/security-intruder-alarm-systems/secureconnect/build-a-system.html
also the new siemens (now vanderbilt) has most of what you want. There is also a an mqtt broker for that panel
There is a member on here that has an mqtt broker for the galaxy range using virtual rios etc.
Id avoid simplisafe its not a pro system, like yale etc. There are tonnes of vids on you tube on how to get around the security of these diy type panels
